Nothing is set to launch its upcoming Phone (3a) series next month on 4 March 2025. Ahead of the lineup’s global launch, both models have made an appearance on the SIRIM database, indicating that the series will be coming here not long after its official unveiling.
Earlier this week, Nothing got SIRIM certifications for two smartphones with the model numbers A059 and A059P. The two models numbers have previously appeared in leaks and are strongly believed to be the Phone (3a) and (3a) Pro respectively.
So far, the only things that have been confirmed about the series are a physical shutter button, a new LED Glyph design, and a Qualcomm chipset. However, a Nothing phone with the model number A059, which was inaccurately presumed to be the Phone (3) at the time, revealed a chip that matches the Snapdragon 7s Gen 3.
According to rumours, the vanilla Phone (3a) will sport a 6.8-inch 1080p AMOLED display with a 120Hz refresh rate along with a triple-camera setup that will included a telephoto lens. On the battery side, it will allegedly be powered by a 5,000mAh cell with support for 45W charging.
