realme is set to launch yet another device under its budget C series called the C75x. Likely related to the C75, the phone has made an appearance on the SIRIM database ahead of any announcements from the brand, indicating an imminent launch.
The C75x was certified by SIRIM on 5 February 2025 with the model number RMX5020. It is unknown when the company is planning to release the smartphone, but it will likely be coming very soon as certain key specs of the upcoming affordable device has already been leaked by a local retailer.
According to the graphic, the C75x will feature an IP69 rating for dust and water resistance, along with drop resistance. Additionally, it will get a battery capacity of 5,600mAh, which is slightly smaller compared to the vanilla model. However, it seems that it will get an upgrade in the screen department as it will sport a 120Hz display.
It is unknown which chipset the C75x will run on, but it will be paired with 8GB of RAM and 129GB of storage. There is no info yet on its camera setup but for reference, the C75 is fitted with a 50MP rear camera and an 8MP front shooter.
