Creative recently launched a new portable wireless speaker called the MUVO Flex and now, it is available in Malaysia. The portable speaker is equipped with Bluetooth 5.3 and supports Auracast, which gives it the ability to share audio to other devices that support the feature for a multi-speaker setup.
On the audio side, the MUVO Flex is fitted with a single 45MM full range neodymium driver with a total power output of 10W. It supports SBC and LC2 codecs and has range of up to 10m. Moreover, the Bluetooth speaker is compatible with smart assistants such as Siri and Google Assistant and it has a built-in microphone, meaning that you can use it as a speakerphone to answer calls.
As for the battery life, the brand claims that the speaker can last up to 10 hours on a single charge with a Type-C port for charging. Durability-wise, it gets an IP67 rating for dust and water resistance.
The MUVO Flex is available for purchase through the brand’s Shopee store at RM169. It is offered in black and grey colour options and it comes with a 1-year warranty.
(Source: Creative)
