Huawei launched three notable products last month that have been made available only via pre-order until today. These were the Mate X6, the nova 13 series, as well as the FreeBuds 4 Pro. After nearly a month-long wait, they are now more readily available via physical and online retail.
In case you missed it, the Huawei mate X6 is the latest foldable by the brand, sporting a 7.93-inch 2440×2240 LTPO OLED main screen with a peak brightness of 1,800 nits. On the outside, it gets a 1080p LTPO OLED panel with an even higher peak brightness of 2,500 nits, both sharing a 120Hz refresh rate. The company has continued to keep the chipset undisclosed, but as mentioned before it is likely a Kirin 9020. It also retains its only configuration of 12GB + 512GB, and powering the device is a 5,100 mAh battery with 66W wired and 50W wireless charging.
For its cameras, the Huawei Mate X6 has a 50MP main + 40MP wide-angle + 48MP 4x optical combo, and 8MP shooters on the inner and external screens for selfies. Its price remains at the previously announced RM8,688.
Then there’s the Huawei nova 13 series, which consists of the base and Pro models, as well as the 13i. All three models retain their asking price of RM1,799, RM2,399 and RM1,299 respectively.
At the time of the previous launch, the company had not revealed the full spec sheet of the nova 13i, but that has since changed, with the official site now listing a Qualcomm Snapdragon 680 chipset, a 6.7-inch Full HD+ 90Hz screen. The memory and storage config remains at 8GB + 256GB, and the camera setup consists of a 108MP main shooter and a 2MP depth sensor.
Moving on to the Huawei FreeBuds Pro 4. As a refresher, these come with 11mm dynamic drivers, memory foam tips, and a battery life of seven hours without ANC, or five hours with. Including the charging case into the equation, and you get a total of 33 hours. Other features include dual connection support, sensors to detect when you put them on or take them off, and the brand’s L2HC 4 codec. These are now available for RM899.
