Ahead of the lineup’s global launch in India next week, realme has quietly listed the 14 Pro Plus in China, revealing its design and specs. Compared to its predecessor, it gets a processor upgrade, a notably bigger battery, improved durability, and a larger display, but the same camera setup.
The 14 Pro Plus sports a 6.83-inch 2800×1272 AMOLED display with a 120Hz refresh rate and a global peak brightness of 1,500 nits. Inside, the mid-ranger runs on a Qualcomm Snapdragon 7s Gen 3 chipset. For protection, it gets an IP69 rating for dust and water resistance alongside Corning Gorilla Glass 7i on the screen.
On the imaging front, the device features a 50MP main camera with OIS, a 50MP telephoto lens with OIS and 3x optical zoom, and an 8MP ultra-wide lens. Backing it is a huge 6,000mAh battery with support for 80W charging. As for biometrics, it is equipped with an under-display fingerprint scanner.
The 14 Pro Plus comes in white and grey colour options with a starting price of CNY2,599 (~RM1,592) for the base trim. While the realme 14 Pro series is set to launch globally in India on 16 January, the company has yet to announce when it will be available in Malaysia.
(Source: realme)
