Videocardz claims to have gotten an exclusive boxshot of Inno3D’s variation of the NVIDIA GeForce RTX 5090 graphics card. Not only that, the card is expected to ship out with double the amount of GDDR7 memory of the RTX 5080, which itself is expected to have 16GB GDDR7 memory.
The Inno3D RTX 5090 is part of the iChill X3 and like the RTX 4090 and RTX 3090 before it, the card is the flagship GPU of the soon-to-be-announced Blackwell architecture. At a glance, the card also looks to feature a huge 3.5-slot thick cooler, which the leakster site says is one of the GPU’s key features.
![Inno3D-iChill-X3-RTX-5090-Leak-2](https://www.lowyat.net/wp-content/uploads/2025/01/Inno3D-iChill-X3-RTX-5090-Leak-2.jpg)
While still unconfirmed, other rumours point to the RTX 5090 being built around the GB202 GPU and will be the only SKU in the RTX 50 Series to use said GPU. It is also rumoured that the card is expected to feature 21,760 CUDA cores, a 512-bit memory bus, and a ridiculously high TDP of 575W.
That last point about the GPU also lends credence to an earlier rumour whereby consumers looking to invest into the RTX 50 Series would need to change out their PSUs, in order to support the GPUs.
NVIDIA’s CES 2025 keynote kicks off tomorrow, so we’ll be getting our answer then. It’s a little ironic though, since the RTX 5080 is expected to hit the shelves before the RTX 5090.
(Source: Videocardz)
