MSI Unveils Its 27-Inch 4K MPG 272URX QD-OLED Gaming Monitor
With 240Hz refresh rate and support for DisplayPort 2.1a UHBR20.
by John Law
January 3, 2025
(Image: MSI.)
(Image: MSI.)
MSI officially pulled back the curtain from the MPG 272URX QD-OLED gaming monitor. Like the ASUS ROG Swift PG27UCDM, the display makes full use of a QD-OLED panel, featuring a 5-layer tandem panel and EL Gen3 technology.
Specs-wise, the 272URX is a 27-inch panel with a maximum resolution of 4K and a 240Hz refresh rate with 0.03ms response time. The pixel density is rated at 166ppi, and it is an NVIDIA G-Sync Compatible monitor.
MSI-MPG-272URX-QD-OLED-1
(Image: MSI.)
MSI-MPG-272URX-QD-OLED-2
(Image: MSI.)
Again, like the PG27UCDM, the 272URX monitor comes with a DisplayPort 2.1a UHBR20 port that supports up to 80Gbps bandwidth, which is how the monitor is able to support the mentioned 4K240Hz on a 27-inch form factor. Other ports include two HDMI 2.1 ports and a USB-C that supports alternate DisplayPort and 98W fast-charging.
The display is also VESA DisplayHDR True Black 400 certified, and comes with MSI’s OLED Care 2.0 technology to prevent burn-in. That, and it also comes with a 3-year burn-in warranty should such an event occur.
MSI-MPG-272URX-QD-OLED-3
(Image: MSI.)
MSI-MPG-272URX-QD-OLED-5
(Image: MSI.)
MSI-MPG-272URX-QD-OLED-4
(Image: MSI.)
The MSI MPG 272URX QD-OLED gaming monitor is expected to make its debut at the brand’s booth at CES 2025. At the time of writing, local pricing and availability have yet to be announced.
(Source: MSI)
Related Article MSI Claw EX 8 AI+ Review: All Hail Panther Lake
Filed Under 272urxmsimsi mpg 272urx qd-oled
Updated 8:15 pm, Fri, 3 January 25
SendShareShareShare4Tweet2
    JPJ To Suspend MyEG, Zetrix AI Services From 5 October 2026
    Mouse / Mouse Pad
    Lenovo Unveils A Transparent Mouse With 90-Day Battery Life (Updated)
    Telco
    BeONE Mobile Officially Launches As Maxis-Powered MVNO
    Tablets
    iQOO Launches Pad Ultra In China; Features Custom Q4 Chip
    CelcomDigi
    CelcomDigi Announces Three Programs As Part Of Next Phase Of CD:NXT
