Alleged specifications of Intel’s upcoming Arc B570 have made their way online. The leak comes just after an official launch date for Battlemage was more or less confirmed by the leakster site, Videocardz.
It should be made clear that the details of the B570 come by way of the ASRock Arc B570 Challenger OC, an AIB partner card. Per the specifications, the card will ship out with 18 Xe2 Cores, 144 XMX Engines, house 10GB GDDR6 memory running at 19Gbps, an engine clock of 2,600MHz, and a 160-bit memory bus. It will run on the PCIe 4.0 8x interface, which is a bit surprising, given that current GPUs run on all 16 lanes.
Additionally, the card will support DisplayPort 2.1, in addition to HDMI 2.1, the latter reportedly being of the UHBR 13.5 variant.
The B570 aside, the same source also shared details about the B580 GPU, confirming details that initially made their way online. The card will ship out with 12GB GDDR6 memory running at 19Gbps, and an engine clock of 2,800MHz. Oddly enough, the ASRock spec sheet doesn’t say how many Xe2 Cores it ships out with but again, based on earlier reports, we know that it should ship out with 20 of them.
Both the B570 and B580 are expected to be announced tomorrow, with their availability set for 13 December.
(Source: Videocardz)
