As previously promised, realme today has officially launched its latest entry-level smartphone, the Note 60. It is available now via the brand’s official online stores on Shopee, Lazada and TikTok, priced at RM399. Unlike its debut in Indonesia a couple of months prior, the local version of the phone is equipped with a lower memory configuration.
In case you missed our prior reports, the realme Note 60 sports a 6.74-inch 720p LCD display with a 90Hz refresh rate and a peak brightness of 560 nits. It also comes with IP64 rating for dust and water resistance and ArmorShell design for drop resistance, while its colour options include Voyage Blue and Marble Black.
![realme note 60 launch msia](https://www.lowyat.net/wp-content/uploads/2024/11/realme-note-60-launch-msia-1.jpg)
Under its hood is a Unisoc T612 chipset, and it should be noted that the Malaysian version only comes with 4GB RAM and 128GB storage, as well as a microSD card slot for expansion. Powering the entry-level device is a 5,000mAh battery with support for 10W charging via USB-C.
![realme Note 60](https://www.lowyat.net/wp-content/uploads/2024/08/realme-Note-60-colours.jpg)
On the imaging side, the realme Note 60 features a 32MP primary camera and a 5MP selfie lens. Besides that, the phone features Android 14 via realme UI 5.0, and a side-mounted fingerprint scanner for user verification.
(Source: realme Malaysia press release)
