Home Smart Home
360 Botslab Announces Three New Security Cameras From RM329
With indoor and outdoor models to suit your needs.
Botslab range
10
IoT brand 360 Botslab has announced a number of smart home monitoring devices for the Malaysian market. Distributed by TRIO locally, the company highlights three home security cameras, one for the indoors and two for the outdoors. All three of them interact with the brand’s mobile app that are on Android and iOS
Starting with the former, there’s the C221, or to go with its full name, the Botslab Indoor Cam 2 Pro C221, this is a 5MP camera that records 3K resolution video. Featuring what is called AI multi-scene detection, the camera has the ability to detect people and pets coming into its field of view. With that, you can get it to send alerts to you when it detects either an intrusion, or even when there’s no one. There’s a capacitive button that allows two way audio communication, but when the button is out of reach, this can also be activated via gestures.
Botslab C221
For the outdoors, there’s the Botslab Outdoor Pan/Tilt Camera Pro W312, which provides 360 degrees of horizontal coverage, and 147 degrees vertically. To go with the wide angles of coverage is the ability to “patrol”, letting it monitor a wider area than its own lens is capable of. It can also track people coming in to view, with automatic zoom to keep them in. The camera itself is a 4MP unit that records 2.5K resolution footage, and it also sports two-way voice comms as mentioned above.
Botslab W312
Finally, there’s the Botslab Outdoor Dual-Lens Camera W302. As the name suggests, this comes with two separate lenses on either side, giving it a wider 170 degrees field of view. Though you do give up the 360 degrees coverage for this. In addition to being able to track people, this model also gets the ability to track vehicles. Speaking of which, both outdoor models are armed with a siren and light alarm combo as well as an IP66 rating to endure the elements.
Botslab W302
The Botslab C221 indoor camera is priced locally at RM329, while the W312 and W302 outdoor ones get RM339 and RM449 price tags respectively. You can get these from the brand’s official stores on both Lazada and Shopee.
Filed Under 360 BotslabBotslabC221CCTVsecuritySmart HomeW302W312
Updated 3:06 pm, Fri, 8 November 24
SendShareShareShare4Tweet3
    Sports
    RTM Tightens RTMKlik Security Amid Claims Of Overseas FIFA World Cup 2026 Access
    Perodua Adjusts QV-E Pricing Downward; Introduces Outright Purchase Option
    Hardware
    DJI Power 1000 Mini Now Available In Malaysia
    iCAUR Malaysia Extends Component Warranty To 10 Years/200,000km
    Gaming
    Microsoft Considers Spinning Off Xbox Into A Separate Company
