Earlier this month, Nokia released two new feature phones in China, the 125 4G and the 108 4G. Both are refreshed 2024 models of existing devices and they are nearly identical to each other, save for the camera.
The two new phones have already been listed by Nokia on its Shopee store, but only the 125 is in stock at the moment. The 125 5G gets a retail price of RM328.90 while the 108 4G costs RM284.90, but as of writing, both models are listed at RM219.
As you can tell from the names, both feature phones support 4G LTE connectivity, but they also come with support for Bluetooth 5.0 and FM radio. They are fitted with a headphone jack, a USB Type-C port for charging and are powered by a 1,450mAh battery.
Display-wise, they sport a 2.4-inch LCD screen while under the hood, they run on a Unisoc T127 chipset paired with 64MB of RAM and 128MB of storage that can be expanded up to 32GB using a microSD card. For photography, only the 125 gets a 0.3MP QVGA snapper on the back, while the 108 is equipped with a flashlight on top to make up for the lack of a camera. On the durability side, the feature phones come with an IP54 rating for dust and water resistance.
