Budget Apple Smart Display May Look Like iMac G4
It will also sport a square screen, oddly enough.
Apple iMac G4
Source: Felix Winkelnkemper / Flickr.
The Apple rumour mill has had quite a run with the much talked-about smart home display with a robotic arm, but a lot less about it supposedly more affordable counterpart. In the latest edition of Mark Gurman’s Power-On newsletter, he’s shared more details about what it would look like, and perhaps by extension the main product itself.
But before we get ahead of ourselves, the supposed lower end Apple smart home display is described as “may be a little smaller than expected”. Gurman cites sources that claim that it will have a square display, “about the size of two iPhones side by side”. Which isn’t much even if you’re generous and look at the largest Pro Max models.
apple store trx interior
This small square screen is also “positioned at an angle on a small base, reminiscent of the circular bottom of the iMac G4”. The newsletter also mentions that Apple may put speakers in this base, which basically turns the device into a HomePod with a screen. Gurman then reiterates that the device is primarily meant to be a device that controls smart home accessories, as well as the tentative release window of next year.
These descriptions for the more affordable option may also apply to the more premium one with the robotic arm, plus likely a larger screen. This is still noted as not hitting the market before 2026, and with a price tag closer to US$1,000 (~RM4,362).
(Source: Bloomberg)
Related Article Apple’s First OLED iPad mini May Launch In October, But There’s A Catch
Filed Under AccessoryAppleHomePodsmart displaySmart Hometablet
Updated 10:04 am, Mon, 28 October 24
    Gaming
    Capcom Pop-Up Store Now Officially Open At LaLaport Bukit Bintang
    Gaming
    Konami Releases Original Castlevania Game For Free On Android, iOS
    Tablets
    Apple Code Leak Reveals iPad 12, iPad mini 8 Details
    Hands On
    Xiaomi 18 Pro Max Hands On: First To Rock The Snapdragon 8 Elite Extreme
    Hybrid Vehicles
    2026 Honda City e:HEV RS Facelift Officially Launches In Malaysia
