Infinix Hot 50 Pro Lineup Unveiled With Helio G100, Bypass Charging
You can choose between having a curved or flat screen.
by Ikmal Rozlan
October 24, 2024
Infinix Hot 50 Pro Plus
Image: Infinix
29
Infinix has introduced two new devices into the Hot 50 series with the Hot 50 Pro and Pro Plus. The two phones seem to be nearly identical smartphones, with the only major difference being in the display and front camera.
The Hot 50 Pro sports a flat 6.78-inch 1080p AMOLED display with a 120Hz refresh rate, a global peak brightness of 550 nits, and local peak brightness of 1,800 nits for HDR content. On the other hand, the Pro Plus gets a curved 6.78-inch 1080p AMOLED display with the same refresh rate and global brightness rating, but a lower local peak brightness of 1,300 nits. For protection, both phones get an IP54 rating for dust and water resistance, but only the Pro Plus gets a Corning Gorilla cover glass.
Infinix Hot 50 Pro
Image: Infinix
Under the hood, both entry-level devices run on a MediaTek Helio G100 chipset paired with 8GB of RAM and up to 256GB of expandable storage, although the Pro can only support a microSD card of up to 1TB while the Pro Plus has a higher limit of 2TB. Connectivity-wise, the two budget smartphones support 4G, Wi-Fi 5, Bluetooth 5.4, and NFC, while on the security side, they are both fitted with an under-display fingerprint scanner.
Hot 50 Pro Plus | Image: Infinix
Infinix Hot 50 Pro
Hot 50 Pro | Image: Infinix
Regarding the optics, the duo features a 50MP main camera and two depth sensors, while for the front camera, the Pro and Pro Plus get an 8MP and 13MP snapper respectively. The phones are powered by a 5,000mAh battery with support for 33W charging and bypass charging.
The price and availability of the Hot 50 Pro lineup has yet to be revealed. As of now, it is unknown if the brand plans to bring the new smartphones to Malaysia.
Related Article Infinix Xbook 14 Neo Now Available In Malaysia; Retails From RM2,199
(Source: Infinix [1][2])
Filed Under hot 50 proHot 50 Pro PlusInfinixSmartphone
Updated 10:15 am, Thu, 24 October 24
SendShareShareShare12Tweet7
    Data Breaches
    AEON Credit Introduces FacePay Via AEON Wallet
    Hands On
    MacBook Pro PROLED XDR (14-Inch) Hands On: Added Touches
