HONOR has officially announced the launch of the 200 Smart, its most affordable option from the 200 series. As revealed by listings from local retailers earlier this month, the smartphone comes with only a single configuration in green and white colour options.
The Smart is fitted with a 6.8-inch 1080p LCD display with a 120Hz refresh rate, a peak brightness of 850 nits, and a side-mounted fingerprint scanner. Inside, the mid-ranger runs on a Qualcomm Snapdragon 4 Gen 2 chipset paired with 8GB of RAM and 256GB in internal storage. For protection, it comes with an IP64 rating for dust and water resistance, as well as a five-star drop resistance rating.
On the optics side, the smartphone comes with a 50MP main camera, a depth sensor, and a 5MP front shooter. Powering the device is a 5,200mAh battery with support for 35W charging. For connectivity, it supports 5G, Wi-Fi 5, Bluetooth 5.0, and NFC.
The 200 Smart retails for RM1,099 and can be purchased through the brand’s Shopee, Lazada, and TikTok stores, as well as authorised retailers. Alternatively, you can get it for free with select postpaid contract plans from CelcomDigi, U Mobile, and Yes, while Hotlink is offering the smartphone at RM89 with its Postpaid 70 plan.
(Source: HONOR Press Release)
