Tuesday, December 16, 2025
  • Wanista
Home Hardware Power Supply
UGREEN Reveals New Nexode Power Bank Series; Starts From RM169
Two different options for both business and pleasure.
by Haikal Nazri
August 23, 2024
NEW-UGREEN's Nexode Power Bank series designed for modern travellers
Image: UGREEN
UGREEN just released its Nexode Power Bank Series which offers two high-output power bank models, each capable of delivering over 100W and are designed to charge smartphones, tablets, and laptops. The design maximises space efficiency, making it compact and light enough to fit into carry-on luggage or in the palm of a hand.
Both power banks support a 65W fast recharging feature, allowing devices to be fully charged within 1.5 hours. With the capacity to fully recharge an iPhone 15 up to four times, both power banks are compatible with a wide array of devices.
Image: UGREEN
One of the models, the Nexode Power Bank 20000mAh 130W, features two USB-C and one USB-A ports, making it ideal for long-distance trips and high-demand activities. It even includes a TFT screen that displays battery information and animated ‘emoji’ faces to indicate charging status.
The other, the Nexode Power Bank 12000mAh 100W, has one USB-C and one USB-A port. It’s essentially designed for daily commuting or short trips, and it also features an LCD display with battery level as well as animated facial expressions.
NEW-UGREEN Nexode Power Bank 12000mAh 100W
The Nexode Series also boasts multiple safety certifications and 13 layers of protection. This includes durable, automotive-grade lithium-ion cells and a V-0 flame-retardant casing. UGREEN’s Thermal Guard system display also provides real-time temperature monitoring and efficient heat dissipation.
You can now purchase the Nexode Power Bank on UGREEN’s official store on Shopee, TikTok Shop, and Lazada, with prices starting from RM169.
(Source: UGREEN [press release])
Filed Under charging stationnexodeportable chargerPowerbankugreen
Updated 4:33 pm, Fri, 23 August 24
https://lowy.at/2knhu
Share1Tweet1SendShare
    Tablets
    Xiaomi Pad 8 Pro To Launch Globally With 9,000mAh Battery
    Seres Enters Malaysia With RM95,000 Seres 3 EV
    Smartwatches
    Amazfit Active Max To Debut With Larger Display And Battery
  • Wanista
