Not long after dummies of the base iPhone 16 appeared online, alleged demo units of the Pro Max variant have also surfaced. In addition to revealing its design, the more recent leak showcases all of the supposed colourways expected at launch for Apple’s top-end model.
According to the image provided by X (formerly Twitter) user @SonnyDickson, the iPhone 16 Pro Max will be available in bronze/brown, which apparently is the only bold colour from the bunch. Apart from that, the device is depicted in the same White, Black and Natural Titanium as its predecessor, while missing is the Blue option.
As for the Pro Max model itself, the phone is shown to sport a similar design to last year’s iPhone 15 Pro Max. The only difference is the camera bump, which now looks to be a separate glass piece rather than integrated seamlessly into the rear plate. Meanwhile, the frames around each lens also appear to be thicker this time around.
— Sonny Dickson (@SonnyDickson) August 1, 2024
Sadly, no view of the iPhone 16 Pro Max’s front was provided, so there’s no way to tell if there are any differences to be expected there. Nevertheless, there’s a high chance that the next-gen model will retain the same Dynamic Island-supported cutout as before, unless Apple decides to bring back the notch for some reason.
Whether this recent leak is accurate remains to be seen, and we’re more or less a month away from finding out. Provided that Apple sticks to its usual schedule, it is expected that the newer iPhones will launch sometime next month.
(Source: SonnyDickson, via X)
