Google Gemini Now Replies “General Questions” Even If Android Device Is Locked
This feature just got a lot easier to access.
by Evelyn Chu
July 18, 2024
google gemini ai
Image: Google
Google Gemini’s new component, now having a generative AI chatbot, can now assist you even when your device is locked.
By pressing your home or power button, you can open Gemini and ask general questions or ask to do certain commands such as reading your unread messages, your emails, or even command it to make phone calls. Although, let’s say the device is unlocked, it can also prompt weather forecasts, schedule reminders, and navigate locations.
Google-Gemini-Locked-Screen-General-Questions-1
(Image source: 9to5 Google.)
For it to respond to more complex questions, you will have to unlock your phone and type it out in the text bubble. Using Gemini from your device’s lock screen doesn’t necessarily open up new capabilities, but it does make accessing information nonchalantly more convenient, especially while driving.
Simply put, instead of unlocking your phone to search something up, you can now just do it hands-free using the voice commands. On that note, the feature will be on by default, but you can turn it off through your Settings app if needed.
(Souce: 9to5Google, Android Police, Google)
Haikal Nazri contributed to this article.
Related Article Google Will Support ChromeOS Until 2034 As It Transitions To Googlebook OS
Filed Under Googlegoogle gemini
Updated 11:50 am, Sat, 20 July 24
    Data Breaches
    AEON Credit Introduces FacePay Via AEON Wallet
    Hands On
    MacBook Pro PROLED XDR (14-Inch) Hands On: Added Touches
