Intel may have unwittingly revealed its upcoming high-end ARC Battlemage GPU for a brief moment in time. The listing has since been taken down but not before the obligatory screenshots by eagle-eyed internet sleuths were taken.
Based on the screenshots, the top-tier Battlemage GPU goes by the code G31. More specifically, it appeared on Intel’s page listing for design tools for the GPU series, as “PTT Engagement – BGA3283-BMG-G31 VRTT Interposer – Prototypes.”
First real evidence Battlemage G31 exists/planned beside G21.
BGA3283-BMG-G31
VRTT Interposer – Prototypes (Internal only)https://t.co/GodAz95w36— Michael (@miktdt) June 29, 2024
The name confirms that the GPU has a ball grid array (BGA) package comprising 3283 pins. Not only that, it is possible that there is also a smaller, lower-tier Battlemage GPU, listed as “BGA2362-BMG-X2 Interposer for the Gen5 VR Test Tool”. This supposed GPU is listed as having 2362 pins.
![Intel Accidentally Confirms Flagship ARC Battlemage GPU With 32 Xe2 Cores 2 Intel ARC Battlemage leak 1](https://www.lowyat.net/wp-content/uploads/2024/07/Intel-ARC-Battlemage-leak-1.jpg)
At this stage, Intel has yet to directly confirm the lineup of the leaked Battlemage GPUs, nor has it said when it can be expected as a separate entity, and not a part of the chipmaker’s soon-to-launch Lunar Lake mobile processors, which will be the first module to launch with the new Xe2 Cores.
(Source: Intel via Videocardz)
