OnePlus has launched a new premium tablet called the Pad Pro, which is packed with the latest high-end chipset from Qualcomm. Aside from the processor upgrade, the Pro also gets a bigger and brighter display than the original Pad, but it is backed by the same battery capacity and charging speed.
The Pad Pro sports a 12.1-inch LCD display with a 3K resolution, a peak brightness of 900 nits, a 7:5 aspect ratio, and a whopping refresh rate of 144Hz. It runs on the Snapdragon 8 Gen 3 chip paired with up to 16GB of RAM and 512GB of storage.
Just like its predecessor, the tablet features a 13MP sensor on the back while the front gets an 8MP camera housed in the horizontal bezel. Powering it is a 9,510mAh battery with support for 67W charging. It also ships with OxygenOS 14.1 based on Android 14.
The Pad Pro is offered in green or grey colour options with several storage configurations, which starts from CNY2,799 (~RM1,817) for the base 8GB+128GB trim. As of writing, it is unknown if the brand plans on bringing the tablet to Malaysia, but it is unlikely given that its last two tablets never launched here.
(Source: OPPO China)
