realme has introduced yet another C-series device called the C61. This time around, the brand is marketing the phone with claims of durability, with the C61 equipped with a metal frame, an unnamed reinforced glass, and an IP54 rating for dust and water resistance.
The budget device sports a 6.5-inch 720p LCD display with a refresh rate of 90Hz. Underneath the chassis, users will find a Unisoc Tiger T612 paired with up to 6GB of RAM and 128GB of storage, along with a microSD card slot for storage expansion. Keep in mind that the configurations offered in Malaysia might differ from the ones in India.
For imaging, the phone gets a single 50MP main camera on the back with a depth sensor alongside it as well as an 8MP selfie shooter up front. Powering the affordable device is a 5,000mAh battery with support for 45W charging, which is quite fast for an entry-level smartphone.
The C65 comes in two colour options and retails for a starting price of INR7,699 (~RM435) for the base 4GB+64GB trim. There is no word yet on when it might be arriving in Malaysia, but the phone was listed on the SIRIM database just recently with the model number RMX3930, indicating that it will likely be launched here soon.
(Source: realme)
