Logitech has launched a new portable keyboard called the Keys-To-Go 2. The Bluetooth keyboard is specifically designed for tablets, hence the focus on portability with a built-in flip cover, but it also works with phones and laptops with the ability to connect and switch to multiple devices.
The Keys-To-Go 2 is made of recycled plastic and is powered by replaceable coin cell batteries, which the brand claims gives the keyboard a battery life of three years before you need to swap them out. It connects to devices via Bluetooth Low Energy and it comes with Easy-switch keys that enable users to quickly switch between three devices.
While it is mainly meant to be used for the iPad, it is also compatible with iPhones and MacBooks, hence where the device switching feature comes in handy. Despite its small footprint, it gets a top row of the typical shortcuts you would find on a regular keyboard such as volume, media playback, screen brightness levels, and more. You even can customise certain functions through the Logi Options+ app, which is available on both Windows and macOS.
The Keys-To-Go 2 is already available in Malaysia through its website, with a price tag of RM419 and two colour options. On a side-note, the keyboard is also compatible with Logitech Flow.
