Apple WWDC 24: iPadOS 18 Improves The Note-Writing Experience
Drop what you're doing, the iPad finally gets a calculator app.
iPadOS 18
Source: Apple.
As part of the WWDC event, Apple unveiled the features that’s coming to its latest tablet operating system, the iPadOS 18. And while the company does not explicitly mention AI in this segment, a fair number of these features actually look like it involves it to some extent.
Starting with the more mundane features of the iPadOS 18 – at least those that are not shared with iOS 18 – one of the new features include a floating tab that can morph into a side bar. The latter is not exactly new, but the former is, for what it’s worth. There’s also a feature that makes it easier to browse your documents as well, though if you’ve titled them well, this seems a tad redundant.
iPadOS 18 tab bar
Source: Apple / YouTube.
But oddly enough, the most interesting reveal about iPadOS 18 is the Calculator app. Yes, it sounds a bit like a joke, and if that was all there was, it would probably be treated as such. But where things get interesting is really the way it integrates with the Notes app. With the update, you can write equations on a note, and the app gets you the answer after you put in the equal sign.
iPadOS 18 calculator
It also works with more complex tasks as well. Put in your equation, change variables and see the answer change in response in a second or two. You can also get this feature of iPadOS 18 to plot a graph for the equation, and by changing the variables you can see the graph change in real time too.
Related Article Apple iPhone 18 Pro Details Reportedly Included In Tata Data Leak
iPadOS 18 calculator graph
Finally, iPadOS 18 will add Smart Script, which will use on-device machine learning to copy your writing style, and also make your writing more legible if needed. You can also paste copied text into your written notes, and the pasted text will mimic your handwriting.
As part of the stream, Apple says that iPadOS 18, alongside iOS 18 and the new macOS, will be available in fall, or between late September and late December of this year. No specific dates yet, but chances are it will be around the time this year’s iPhones become available.
(Source: Apple [1], [2])
Filed Under AppleCalculatoriPadOS 18Smart ScriptWWDC 2024
Updated 3:01 am, Tue, 11 June 24
    Gaming
    Capcom Pop-Up Store Now Officially Open At LaLaport Bukit Bintang
    Gaming
    Konami Releases Original Castlevania Game For Free On Android, iOS
    Tablets
    Apple Code Leak Reveals iPad 12, iPad mini 8 Details
    Hands On
    Xiaomi 18 Pro Max Hands On: First To Rock The Snapdragon 8 Elite Extreme
    Hybrid Vehicles
    2026 Honda City e:HEV RS Facelift Officially Launches In Malaysia
