If you’re unfamiliar with the name Oukitel, the Chinese phone maker has been around for awhile, making mostly affordable phones. The standout features for these phones are usually their larger than average batteries, especially for their time. And the brand has a new phone that you can now buy, in the form of the Oukitel WP33 Pro.
As far as its spec sheet goes, the Oukitel WP33 Pro would probably be considered a midranger. It starts off with a 6.6-inch Hull HD+ screen, a MediaTek Dimensity 6100 Plus chipset, 256GB of storage space and 8GB of RAM. It also doesn’t get the latest version of the Android operting system, as it runs Android 13.
But as mentioned, the primary draw of the Oukitel WP33 Pro is its battery, rated at 22,000mAh. That being said, it’s charging rate is not as impressive, at 33W, but it does support 28W reverse charging. The entire package comes in a pretty rugged body, complete with an IP68 rating.
Behind, the Oukitel WP33 Pro has a 64MP main +20MP night vision + 2MP macro shooters. Also worth mentioning is that it has a 5W 36mm speaker in the middle of its camera island at the back, with a peak volume of 136dB. In front, it has a 32MP shooter in a water-drop notch.
The Oukitel WP33 Pro has an asking price of RM1,505, and you can get it from the brand’s official store on Shopee, linked below. But if you do intend to pick one up, it’s worth pointing out that the device is shipped from Mainland China so there might be some waiting time involved. From the reviews in the same page, chances are you’ll get your device within seven days.
(Source: Oukitel / Shopee)
