The realme GT5 was launched back in August last year, with prominent leakster @OnLeaks claiming it to be the GT Neo 6 a month before. More recently, there are signs that hint at the actual realme GT Neo6 getting launched soon. The phone has appeared on Chinese online retailer JD.com with some items on the spec sheet being revealed as well.
From the listing, the realme GT Neo6 will be sporting a Qualcomm Snpadragon 8s Gen 3, with an internal storage of up to 1TB. Its battery capacity is not mentioned, but instead the page shows a 120W charging rate for the phone. No other items on the spec sheet was mentioned.
That being said, The Tech Outlook claims that the realme GT Neo6 will have similar specs as the Neo 6 SE. This could mean a 6.78-inch AMOLED 1.5K screen and a 120Hz refresh rate, as well as a 5,500mAh battery. In the same vein, it could mean a 50MP main + 8MP wide angle camera combo at the back and a 32MP shooter in front.
The JD.com listing does not mention an announcement date, but considering the page, it probably won’t be too long. These bits on the speculative spec sheet of the realme GT Neo6 will also be confirmed then.
(Source: JD.com via The Tech Outlook)
