Wednesday, December 31, 2025
  • Wanista
Home Mobile
Infinix GT 20 Pro Hands On: Less Gaudy, Still Fancy
Though the colour variants may have something to do with that.
Infinix GT 20 Pro
Infinix GT 20 Pro
The Infinix GT 20 Pro saw its launch today, confirming its asking price of RM1,299. But the company passed us the phone a little earlier prior to the launch to get a quick first impression of the device. So here are some quick thoughts about the phone.
Just as when the supposed design sketch of the phone first made its way onto the internet, it’s easy to mistake the Infinix GT 20 Pro for its predecessor. But upon closer inspection, there are a few key differences between the two, at least on the outside, and price notwithstanding.
Infinix GT 20 Pro Mecha Loop LED
To start, the Infinix GT 20 Pro has lost some of its transparency. Or more specifically, most of the details on the back now look look like they are on the back plate, rather than beneath it. Granted, there are still parts that look layered, but it’s overall a cleaner and less gaudy look to it. Incidentally, it also feels less hollow compared to the predecessor.
That being the case, the end result is still a pretty aggressive gamer aesthetic to it. For what it’s worth, the parts that you’d think would light up actually do now, in what is called the Mecha Loop LED lighting.
Infinix GT 20 Pro top
In hand, there is some heft with the Infinix GT 20 Pro, at least more so than you’d generally expect from a phone within this price range. This may have something to do with the 5,000mAh battery found within. Either way, it gives a pretty solid feel to the phone, which can help it from slipping from your grip, as the sides and back are pretty smooth and slippery.
ALSO READ:  Deputy Home Minister: Government Drafting New Bill Against Cybercrime
On that note, the edges on the front is smoother than the back, so depending the way you hold the phone you may experience some discomfort, especially if you rub your fingers strongly off the rear edges.
Infinix GT 20 Pro camera island 2
It’s mostly the same with the now two-tiered elevation of the camera island at the back, with the first elevation having a slight brushed metal texture to it. For both, while you wouldn’t notice them for the most part, the edges are sharp enough to cause discomfort if you hold the Infinix GT 20 Pro the wrong way, especially if there’s some aggressive hand movement in the heat of the moment.
The user experience with the Infinix GT 20 Pro is pretty good. Swiping between home pages and scrolling through websites and social media is pretty smooth, what with the MediaTek Dimensity 8200 Ultimate chipset running within. Of course, the 144Hz of the 6.78-inch AMOLED Full HD+ screen also helps.
Infinix GT 20 Pro front hand
The phone also has stereo speakers, being top- and bottom firing. In a sense, this is better than the asymmetrical setup that makes one of them front-firing and not the other, so even if the two speakers are not exactly aligned, they still sound more balanced. This is especially when held horizontally, even if one speaker doesn’t fire directly into your palm. Top end volume is pretty high too, but as you’d expect there’s mild distortion as the very top end.
We didn’t quite get the chance to give its imaging capabilities a try, unfortunately. But for what it’s worth, it has a 108MP main + 2MP depth sensor + 2MP macro combo doing the job at the back.
ALSO READ:  Infinix GT 30 To Launch In Malaysia On 11 September
Infinix GT 20 Pro hand
To reiterate, the Infinix GT 20 Pro is available starting today for RM1,299. It is available in three colours, which are Mecha Blue, Mecha Orange and Mecha Silver, the last one being what you’ve seen in this article.
Filed Under gt 20 proHands OnInfinixMalaysiaOfficial
Updated 4:00 pm, Thu, 2 May 24
https://lowy.at/oZhnf
Share4Tweet2SendShare
    Banking
    Bank Negara Monitors Agrobank After Reported Loss Of Up To RM165.75 Million
    E-commerce
    Logistics Company Flash Express To Shut Down Malaysia Operations In January 2026
    Perodua Rumoured Of Possible RM500 Million Acquisition Of TCMA Assembly Plant
    Storage
    Redditor Orders Two Samsung 9100 Pro SSDs, Receives RM24,200 Worth Of SSDs Instead
    2026 Keeway EZI TS1 Arrives In Malaysia With A Price Tag Of RM4,288
  • Wanista
