LG has officially announced new models of its UltraGear curved OLED gaming monitors, in the form of the 34GS95QE and 39GS95QE. As the first two numbers suggest, these are available in two different sizes, and they are both available for pre-order until 19 May.
Going over what these monitors offer, the LG GS95QE UltraGear monitors come with a curvature of 800R, a WQHD (3,440 x 1,440) resolution and a 21:9 aspect ratio. Also part of the spec sheet are its 240Hz refresh rate and 0.03ms GtG response time. It also has a peak brightness of 1,300 nits for when that is needed.
Other key features of the LG GS95QE UltraGear monitors include support for two different sources via either PBP (picture by picture) or PIP (picture in picture). As for the quality of the picture itself, the company says that the monitor has a typical colour gamut of DCI-P3 98.5%. Available ports include two HDMI 2.1 ports and a DisplayPort 1.4, as well as a USB 3.0 upstream port and two USB 3.o downstream ports.
The 34-inch LG 34GS95QE UltraGear monitor has a RM5,999 price tag, while the 39-inch LG 39GS95QE UltraGear monitor instead costs RM6,999. The company is currently having them up for pre-order on Lazada, until 19 May 2024. You can find out more about the monitor by hitting this link. To place your own pre-order, if you’re so inclined, you can do so by hitting this link instead.
