The new Dell Latitude 7350 Detachable is now available in Malaysia. As with other laptop brands, the tablet PC comes equipped with Intel’s latest 14th Gen Meteor Lake CPUs.
Specifically, consumers will have a choice between an Intel Core Ultra 7 164U or a Core Ultra 5 134U. Other internal specifications include up to 32GB LPDDR5X RAM running at 6400MT/s, and up to 1TB of PCIe 4.0 storage. That’s all powered by a 46.5Whr 3-cell battery. Regardless of the choice of internal components, all variants of the Latitude 7350 Detachable are equipped with the same 13-inch 3K (2880X1920) IPS touch display.
To charge the Latitude 7350 Detachable, the laptop is bundled with a 65W USB-C power adapter, which also means that it should be compatible with any 65W charging adapter or higher. Alternatively, you can opt for a 60W USB-C charging adapter but you’ll have to fork out an additional RM79 if you want it.
You can customise your version of the Latitude 7350 Detachable on the official Dell product store page. As mentioned in the title, pricing for the laptop starts from RM10,409 for the base model, while the top-specced SKU – sans the software and security options – will set you back RM11,877.
