The vivo V30 and the V30 Pro had their debut at different times and different locations, but it looks like the company is keeping things a bit simpler this time around. For the local market, the company has decided to launch both simultaneously.
In case you missed it though, the base model vivo V30 has a 6.78-inch 1,260 x 2,800 AMOLED display with 2,800 nits peak brightness and 120Hz refresh rate. Inside, it has a Qualcomm Snapdragon 7 Gen 3 chipset and a 5,000mAh battery that supports 80W charging. The cameras are a highlight here, with the rear combo consisting of a 50MP main + 50MP wide-angle cameras. Another 50MP camera sits in a punch-hole cutout of the screen.
As for the vivo V30 Pro, we’re looking at the same screen and battery, but the chipset has been swapped out for a MediaTek Dimensity 8200. It’s much the same story with the cameras, except the back sports a triple-camera setup with an extra 50MP 2x zoom telephoto shooter in addition to the existing ones. Worth mentioning also that both models sport an IP54 rating.
The vivo V30 comes in two RAM and storage configurations, which are 12GB + 256GB and 12GB 512GB, which are priced at RM1,999 and RM2,199, respectively. Only one config for the Pro model though, which is 12GB + 512GB, and a corresponding price tag of RM2,599. They won’t be available immediately though, as the vivo V30 will only hit shelves on 16 March. The vivo V30 Pro, on the other hand, gets its turn on 30 March.
