If you are a Maxis Postpaid customer, then you may be aware of the option to get additional supplementary lines via the Maxis Postpaid Share 48. If you already have gotten supplementary lines this way, there’s good news for you. The telco has upgraded the amount of data you get this way by 20GB.
This means that every supplementary line added via the Maxis Postpaid Share 48 now comes with 50GB of additional data rather than 30GB. For existing customers, the upgrade is being rolled out in stages, and should be completed by 8 March 2024. You’ll also be given the full 20GB of additional data rather than have it being pro-rated.
Also, this is also not something that’s exclusive to existing Maxis Postpaid Share 48 customers. New signups can also make use of the additional data, with the additional benefit of getting access immediately rather than facing the possibility of having to wait. Of course, other restrictions apply, like the number of supplementary lines you can get this way being dependent on your primary postpaid plan.
Speaking of which, the upgrade was quietly added to the Maxis Postpaid Share 48 FAQ page. You can visit said page by hitting the link below.
(Source: Maxis)
