Chinese accessory brand SHARGE has announced a couple of power banks over the last few months, and now the company has another one entering the local market. It’s called the SHARGE Flow Mini, and compared to the other two, this new one is pretty modest in comparison, in both what it offers as well as its asking price.
To start, the SHARGE Flow Mini comes with a capacity of only 5,000mAh, which is smaller than the battery of some phones these days. Its charging speed also doesn’t exactly scream “fast charging”, at 12W. But on the flip side, it is pretty lightweight, measuring in at less than 100g. It is also designed in a way that allows it to be connected to a phone as if it were an extension of the device, and it works even when said phone has a case attached.
This primary plug on the SHARGE Flow Mini comes with a USB-C connector, but this is interchangeable for a Lightning connector option for those using an iPhone 14 or older. Then there’s the secondary integrated USB-C cable that can be used to charge another device, while also serving as a lanyard loop when stowed away.
Quality of life features aside though, there’s no getting around the 5,000mAh capacity and 12W charging rate of the SHARGE Flow Mini. So it stands to reason somewhat that it has an asking price of RM199. But if this is something that interests you, the company says that it is available today via its official store on Shopee and Lazada.
