In addition to its latest and updated laptops, Razer also launched its own USB Dock for laptops. Specifically, it’s an 11-in-1 multiport adapter, designed to provide additional connectivity ports and more.
It’s not just any run-of-the-mill USB Dock either. Like its laptops, Razer has crafted this accessory using the same CNC technique, molding it out of a single aluminium block. If that wasn’t enough, the entire accessory is also anodized, therefore making it scratch-resistant and making one solid component, quite literally.
Then there are the 11 ports and features that come with it. For a start, it comes with three USB-C 3.2 ports, one of which connects the dock to the laptop and supports 85W charging, allowing you to charge your laptop while having the USB Dock connected. On that note, the second USB-C 3.2 port supports PD charging up to 100W.
Other ports on the USB Dock include two USB-A 2.0 ports, two USB-A 3.2 ports, SD UHS-I and microSD UHS-I card slots, a Gigabit LAN Port, 3.5mm audio combo jack with support for Razer’s 7.1 Surround Sound, and one HDMI port that supports 4K60 output.
The Razer USB Dock is available starting today and retails for RM599.
