The realme C67 has now officially made its way into the Malaysian market, less than a month after it debuted in India. With its local launch, the phone is being offered in two variants with two colourway options including Sunny Oasis and Black Rock.
For the specs, the C67 sports a 6.72-inch 1080p LCD display that differs from its India counterpart by having a lower 90Hz refresh rate but a higher peak brightness of 950 nits. The affordable device is also equipped with the Mini Capsule, the company’s version of Dynamic Island.
Inside the chassis is a Snapdragon 685 chipset from Qualcomm with 8GB of RAM and up to 256GB of internal storage, along with a microSD card slot for expansion in case you need more. Connectivity-wise, the C67 supports 4G, Wi-Fi 5, NFC, and Bluetooth 5.0 with a 3.5mm audio jack as an added bonus.
For photography, the brand equipped with C67 with a 108MP primary unit on the back along with a depth sensor, while the front contains an 8MP selfie camera. Powering it is a 5,000mAh battery with support for 33W wired charging.
The C67 is priced at RM799 for 128GB of storage while the variant with 256GB costs RM899. It will go on sale starting 6 January through the company’s Shopee, Lazada, and TikTok stores as well as authorised dealers. From 6 January to 20 January, the phone will come with a pair of earphones for offline purchases while online purchases will be offered with earphones, an extended warranty, and a power bank.
(Source: realme Press Release)
