Xiaomi has confirmed the upcoming arrival of the Note 13 series through a countdown page on its website. According to the site, the lineup will be revealed for the local market on 15 January at 6 PM, but it’s unknown if all three models will be made available here.
The series is made up of the standard model as well as the Pro and Pro Plus variants. Both the vanilla Note 13 and the Pro Plus have already received SIRIM certification, but the middle child Pro has yet to make an appearance on the local database. However, this does not definitively mean that Xiaomi will be excluding the Pro from the Malaysian market.
The base model sports a 6.67-inch AMOLED display with a 120Hz refresh rate and a peak brightness of 1,000 nits. It runs on a MediaTek DImensity 6080 chipset and a 5,000mAh battery with support for 33W charging. On the photography side, it features a 108MP main camera on the back with a depth sensor next to it.
For the higher-end Pro Plus, it is equipped with a 6.67-inch 120Hz OLED display with a peak brightness of 1,800 nits. Under the hood, it operates using the Dimensity 7200 Ultra chip with the same 5,000mAh battery capacity but with much faster 120W charging. For the cameras, the phone offers a 200MP primary unit, an 8MP ultra-wide, and a 2MP macro lens.
(Source: Xiaomi)
