The realme GT3 has finally landed in Malaysia, arriving around ten months after its initial reveal during MWC 2023 earlier in March. Priced at RM2,799, the new flagship handset packs a Snapdragon chipset and an impressive fast charging rate of 240W.
Just in case you missed our prior coverage, here’s a refresher of the phone’s specifications. Starting with its display, featured on the realme GT3 is a flat 6.74-inch AMOLED panel with 1240 x 2772 px resolution, 144Hz refresh rate, 1 billion colour output, 1400 nits peak brightness, and supports HDR10+. Additionally, it comes with an under-display fingerprint scanner, stereo speakers and “Pulse Interface System” lighting on its back, which is used to indicate charging status and notifications.
On the inside, the phone is equipped with a Snapdragon 8+ Gen 1 chipset with 16GB of RAM and 1TB of internal storage. It also features a massive 6,580mm² vapour chamber, dual-side NFC support, Wi-Fi and Bluetooth 5.3 wireless connectivity, as well as a 4,600mAh battery with the aforementioned 240W fast charging support via USB-C.
For photography and video, the realme GT3 comes equipped with a triple camera setup on its back, comprising a 50MP primary sensor with OIS, an 8MP ultra-wide, and a 2MP microscope. Meanwhile, housed within the punch-hole cutout on its display is a 16 MP front-facing camera.
As mentioned earlier, realme’s newly arrived flagship is priced at RM2,799 and is available now via the brand’s official Shopee and Lazada online stores, in addition to its experience stores as well as authorised dealers across Malaysia. Unlike its global launch though, colourways offered for the local market only consist of Pulse White and Racing Purple.
