Unifi revamped its mobile data offerings under the UNI5G name, with the first plans using the new name unveiled earlier this year. Today, the ISP has announced three family plans being added to the lineup. They are the UNI5G Postpaid Family 129, 159 and 189.
Despite the different monthly costs that their names indicate, the basics of the UNI5G Postpaid Family plans are mostly the same. All three offer unlimited 4G and 5G data, with unlimited calls and a 5G phone thrown in as a bonus. The difference between them are the available selection of free phones, the amount of data available for hotspot use, and the number of free supplementary lines.
Paying RM129 a month gets you 150GB of hotspot data and one free supplementary line. This goes up to 200GB with two supplementary lines for the UNI5G Postpaid Family 159, and 250GB with three free lines with UNI5G Postpaid Family 189.
It’s probably worth pointing out at this point a number of items on the fine print. To start, the unlimited data is locked to the principal lines, with each supplementary line only getting a 30GB monthly data allocation. The same goes to their hotspot data allocation, which is also limited to 30GB.
Another thing to note is that these family plans are only offering unlimited data as part of a launch promotion, which ends on 31 January. Sign up after that point, and each plan will only have data allowances equal to their hotspot allocations.
In addition to the family plans, Unifi has so updated its postpaid plans for individuals. To start, the UNI5G Postpaid 39 has its hotspot allocation bumped up to 30GB, the same as the regular mobile data quota that the plan affords subscribers.
Then there’s the UNI5G Postpaid 69, which will be replacing the old Postpaid 65 plan. For the extra RM4 a month, your hotspot allocation is bumped up to match the 60GB monthly data. You also get unlimited 5G data for two years, but only specifically for 5G, as data consumption via 4G will be counted towards the usual 60GB monthly limit.
Finally, there’s the UN5G Postpaid 99, which will take the place of the old Postpaid 89. Like with the family plans, you’ll have to sign up for this before 31 January to enjoy unlimited data. Do so after, and you’ll have a 100GB monthly data allocation instead. For what it’s worth, like the other plans, hotspot data allocation now matches the amount you would normally get per month.
Unifi also says that if you are a customer of both its fibre and mobile offerings, you can get a RM20 rebate of your monthly bill in perpetuity. This is part of its current family-centric campaign with a mouthful of a name. You can find out more by visiting the official site, linked here.
