Last month, the realme 11x arrived in Malaysia but was exclusively available through U Mobile’s postpaid bundles. Now, the smartphone is also available for subscribers of Unifi Mobile, but they’ll have to be on one of the Home and Mobile Internet plans.
As a refresher, the realme 11x sports a 6.72-inch 1080p LCD display with a 120Hz refresh rate and a peak brightness of 680 nits. Inside, it runs on a MediaTek Dimensity 6100 Plus chipset paired with 8GB of RAM and 128GB of internal storage, along with a microSD card slot for up to 2TB of storage expansion. On the connectivity side, it supports Wi-Fi 5, Bluetooth 5.2, and it is equipped with a 3.5mm headphone jack.
For the cameras, the rear module features a 64MP primary camera next to a depth sensor while the front holds an 8MP selfie shooter. Regarding the battery, it has a 5,000mAh capacity with support for 33W fast charging.
Unifi Mobile’s Home and Mobile Internet plans start from RM149 per month with a 24-month contract. The base plan gets you a home internet speed of 100Mbps while the most expensive plan at RM398 per month offers speeds of up to 2Gbps. All the plans are bundled with UNI5G Postpaid 89 as well as a selection of free 5G smartphones. The realme 11x in particular is valued at RM999.
(Source: realme Press Release)
