Asus is officially launching the ZenBook Pro 14 OLED. The laptop is one of the brand’s most powerful, compact, think and light laptops, weighing in at 1.6kg.
The ZenBook Pro 14 OLED also sports a 14.5-inch display, with a maximum resolution of 3K (2,880 x 1,800) and refresh rate of 120Hz. Additionally, not only is it an OLED panel, the display is also a touchscreen, has a peak brightness of 550 nits, and a 100% DCI-P3 colour gamut. Adding on to the list, the display is also Pantone Validated, as well TUV Rheinland-certified for eye care.
Internally, the ZenBook Pro 14 OLED houses the Intel 13th Gen Core i9-13900H, an NVIDIA GeForce RTX 4070, 32GB DDR5 RAM, and 1TB of NVMe Gen4 storage. Powering the entire portable machine is a large 76Whr battery, which is about the same size as the battery inside ASUS’ gamer-centric ROG Zephyrus G14 laptops. For another gamer-related note, the laptop also supports MUX Switch.
Connectivity and ports-wise, the Zenbook Pro 14 OLED comes with one Thunderbolt 4 USB-C port, one USB-C 3.2 Gen2 port, one USB-A 3.2 Gen2 port, an HDMI 2.1 port, an SD card reader, and a combo audio jack.
The ASUS Zenbook Pro 14 OLED will be available from 19 September via all authorised resellers and official ASUS stores. The laptop will retail for RM10,999.
(Source: ASUS PR)
