From the router to the cables, Malaysians aren’t shy about spending a pretty penny just to get nothing but the best WiFi connection available in the market, costing upwards of hundreds of Ringgit alone. However, more often than not, you’re only paying for the data speeds and these insane prices don’t even include all the necessities for your “high-speed” internet.
What if there is a wire-free internet connection that lets you enjoy broadband and even fibre-like speeds for your home WiFi without putting a hole in your wallet? Well, there is now a solution to all your troubles.
Introducing the new U Home 5G by U Mobile, and here’s what you need to know.
If you sign up for the U Home 5G plan, you can have:
- Unlimited 5G Broadband: Easily get fibre-like speeds even in areas with no access to fibre and enjoy 5G connection anytime and anywhere.
- Contract-Free, Hassle-Free!: Skip the paperwork and be free from contracts thanks to the ultimate flexibility of U Home 5G, so you can enjoy your data the way you want.
- No Installation Needed: Experience greater convenience with their wire-free, plug-and-play system, letting you use your data immediately, no appointments required!
- Lowest Price For The Best Performance: Get the best bang for your buck as you get the best value compared to other plans in the market.
All of this is possible because the U Home 5G is a SIM-only plan. However, you can maximise your data speeds at home by trying out these recommended routers with SIM card compatibility, so you can unleash U Home 5G’s full potential.
Bring home 5G data for only RM78 per month, but if you sign up during the launch promo, you get to enjoy a RM10 rebate for life, which makes it only cost RM68 to enable 5G Data at Home! Hurry before the promo ends! For more information or to get your own U Home 5G, kindly visit U Mobile’s official website and start getting more for less today.
This article is brought to you by U Mobile.
