A new leak claims to reveal most of the key specs of the upcoming realme GT Neo 5 Pro. The device is expected to be the brand’s latest flagship following the debut of the vanilla GT Neo 5. While it’s expected to get a spec bump in most areas, it could possible arrive with slower charging speeds than its lower-end counterpart.
The GT Neo 5 Pro is expected to sport a flat 1.5K resolution OLED display with a high refresh rate of 144Hz and the same 6.74-inch size as the base model, according to reliable tipster Digital Chat Station. It’s unknown if it will feature the same transparent window on the back that shows off the SoC.
Speaking of which, the Pro is said to run on the Snapdragon 8 Gen 2 chipset from Qualcomm, although there have been rumours that it could go with the upcoming Snapdragon 8 Plus Gen 2 instead, which is speculated to debut in July. This will likely be paired with 16GB of RAM and up to 512GB of internal storage.
Details of the rear-camera setup are still scarce, but earlier reports claim that the GT Neo 5 Pro could carry the same 50MP Sony IMX890 as its main sensor. DCS also mentioned that the photography capacilities of the phone will be improved by a new fusion algorithm.
So far, there is no information yet regarding the battery capacity but for reference, the two versions of the Neo 5 are equipped with 4,600mAh and 5,000mAh batteries with support for 240W and 150W charging respectively. As for the Pro, it might possibly be downgraded to 100W charging.
The GT Neo 5 is confirmed to be marketed as the GT3 in Malaysia, but no launch date has been revealed yet. As for the GT Neo 5 Pro, it is expected to be unveiled sometime in Q3.
(Source: Gizmochina)
