Logitech has announced a new mouse for those who work on the go, in the form of the MX Anywhere 3S. Looking pretty much like the mouse that came before it, the MX Anywhere 3, there are some notable upgrades under its shell which the company claims makes this its most advanced wireless compact mouse.
As with any mouse, be it for gaming or productivity, the optical sensor is where most of the magic is at. And for the Logitech MX Anywhere 3S, the brand says that this is an 8K DPI optical sensor that “tracks on virtually any surface, including glass”. Which is great as glass is usually the surface that many optical mice struggle with, and this really allows it to be used just about anywhere.
![Logitech MX Anywhere 3S side](https://www.lowyat.net/wp-content/uploads/2023/05/Logitech-MX-Anywhere-3S-side.jpg)
Beyond just the sensor, Logitech has also equipped the MX Anywhere 3S with what it calls the Quiet Click technology, with what it does being pretty self explanatory. An existing feature that has appeared in the brand’s prior mouse is the MagSpeed scroll wheel, which is making another appearance here to smoother scrolls to go with the silent clicks.
Connectivity for the MX Anywhere 3S is good old Bluetooth, with it being able to connect to up to three devices at a time. It is also compatible with the Logi Bolt USB Receiver, which is sold separately. The battery capacity is not specified, but Logitech says that it can last for 70 hours with a full charge. A minute’s charge can also provide three hours of use. The process itself is done via USB-C.
![Logitech MX Anywhere 3S top](https://www.lowyat.net/wp-content/uploads/2023/05/Logitech-MX-Anywhere-3S-top.jpg)
The Logitech MX Anywhere 3S is priced at RM369, and is available on its official stores on Shopee and Lazada, as well as authorised retailers. You can find out more on the product via it’s official page, linked below.
(Source: Logitech)
