The possession of a water purifier at home is now standard practice; it is neither unusual or distinctive. But the majority of water purifiers—possibly even the one you already own—are built with plastic internal water pipes, which actually isn’t the best nor safest option for you.
Plastic pipes all prove to be less effective in terms of strength, durability, and heat resistance, when compared to stainless steel pipes. Which is why the new LG PuriCare™ Tankless Water Purifier with 4-stage All Puri Filter System is now equipped with internal stainless steel pipes that are resistant to corrosion so that you can enjoy water in a more hygienic way.
Stainless steel pipes have a much higher mechanical strength and resistance to a wide range of temperatures and pressures than plastic pipes. That being said, it also ensures that they are more durable and are much less susceptible to bacteria, mould infections and chemical corrosion.
Alongside their 4-Stage All-Puri Filter System which removes nine harmful heavy metals and 99.99% of norovirus, getting healthy and pure water is and will be effortless thanks to this New LG PuriCare™ Tankless Water Purifier.
But if you’re interested and want to know even more, click on the video above or visit the Lowyat TV YouTube channel so see and hear everything you need to know about the new LG PuriCare™ Tankless Water Purifier.
And if you want in on only the purest and cleanest water, it can be yours for only RM65/per month, just head over to the official LG website.
This article is brought to you by LG.
