Tecno is officially bringing over three devices from its new Spark 10 series into the Malaysian market with the base model, the 5G model, and the Pro. The lineup was unveiled earlier this month in India and a local launch was teased recently, offering entry-level phones at affordable price points.
The 4G-enabled Spark 10 and its 5G counterpart both sport a 6.56-inch 720p display with a 90Hz refresh rate while the Pro uses a 6.78-inch 1080p 90Hz screen. Additionally, the Pro is the only one in the lineup with a punch-hole cutout, while the other two have dew-drop notches for the front camera.
The vanilla Tecno Spark 10 and the Pro both run on the MediaTek Helio G88 chipset, whereas the most expensive of the bunch, the 5G version, is equipped with the MediaTek Dimensity 6020. All three are paired with 8GB of RAM, with 128GB of storage for both variants of the Spark 10 and 256GB for the Pro, although they all come with a microSD card expansion slot.
When it comes to the camera, the entire series shares the same 50MP main sensor on the back with the second camera being unspecified but is presumably a depth sensor. Up front, the Pro gets a 32MP selfie shooter while the non-Pro phones house 8MP snappers.
Powering the three phones are 5,000mAh batteries with support for 18W charging. When it comes to connectivity, the phones support dual-band Wi-Fi, NFC, dual-SIM, and an unspecified Bluetooth version — as you can tell from the naming, only the 5G model supports 5G connectivity.
The Tecno Spark 10 series is priced at RM599 for the vanilla version, RM699 for the Pro, and RM799 for the 5G model. It will be available starting on 2 April and for those who purchase it from the launch date to 8 April, they will get a RM50 discount, a pair of wireless earbuds for the standard variant, and a wireless Bluetooth speaker for the purchase of the Pro or 5G model.
(Source: Tecno/Shopee)
