Aside from the m16 as well as its 18-inch counterpart, the m18, Dell Malaysia has also begun taking orders for the other new 16-inch gaming laptop in its stable. Similar to the M-Series models that we mentioned earlier, the Alienware x16 also made its debut at CES 2023 back in January.
Product Director of Alienware, Ryan Gu pointed out that the x16 is meant as an answer to those who can’t decide between a 15-inch and 17-inch gaming laptop. With an aspect ratio of 16:10, Malaysian customers can choose to have the laptop with either a 165Hz or 240Hz display panel for its 16-inch display which also has a native resolution of 2560 x 1600 and support for Dolby Vision.
At the moment, the Malaysian variant for the x16 comes with only one CPU, GPU, and RAM option which is the Intel Core i9-13900HK, NVIDIA GeForce RTX 4080 12GB, and 32GB LPDDR5-6000. It also comes standard with the CherryMX ultra low-profile mechanical keyboard with per-key RGB lighting alongside a 90Whr lithium-ion battery and Lunar Silver colourway.
Meanwhile, Ryan noted that the x16 features a more robust chassis as compared to last year’s x17 R2. The new model continues to feature an illuminated RGB touchpad just like x17 R2 but the version on the x16 is 15% larger than its 17-inch counterpart and he has also highlighted the x16’s six-speaker audio system which features two top-firing tweeters and dual woofer configuration alongside support for Dolby Atmos.
If you are interested to get your hands on one, just head on to Dell Malaysia’s website right here to place your order.
