Saturday, December 13, 2025
  • Wanista
Home Hardware
Corsair Launches New RMx Shift ATX 3.0 PSUs For Desktop PCs
The new PSU literally shifts the entire connector panel to the side.
by John Law
February 2, 2023
Corsair launched its new RMx Shift PSU lineup at the end of last month. Available in wattages ranging from 750W to 1200W, the new power supplies, which are also ATX 3.0 certified components, are one of the world’s first PSUs to literally shift the entire connector panel from the back to the side.
The idea behind the design of the RMx Shift lineup’s design is both simple and straightforward: to provide users with less stressful and easier access to the cables, as well as to provide a much easier and cleaner way to perform cable management.
YouTube video
Regarding the last note, the RMx Shift’s repositioned connector panel also provides a cleaner view, allowing users to easily attach and detach their cable, without first having to slightly unscrew the PSU from the chassis, let alone second guess if you’re successfully connected because you can’t see beyond your hand that you had to uncomfortably contort in order to access said panel.
As per Corsair’s official press release, “Every model of RMx SHIFT is ATX 3.0 certified and PCIe 5.0 compliant for powering the latest cutting-edge systems, helping to improve overall system performance and reliability while providing the power needed to operate at the highest levels. With an included high-quality PCIe 5.0 12VHPWR GPU cable, the RMx SHIFT Series is ready for use with modern graphics cards such as the NVIDIA GeForce RTX 40 Series.”
(Image source: Corsair.)
“The RMx SHIFT Series comes equipped with all the features that PC builders have come to expect from the RMx name. Only connect the cables your system needs thanks to fully modular CORSAIR Type 5 Gen 1 micro-fit cables. A 140mm fluid dynamic bearing fan utilizes a specially calculated fan curve for high performance, low noise, and superior reliability, with support for Zero RPM fan mode for near-silent operation at low loads. 80 PLUS Gold and Cybenetics Gold-certified, the RMx SHIFT Series is rated for steady power output at up to 90% efficiency. 100% 105°C-rated Japanese electrolytic capacitors guarantee unwavering power delivery and long-term durability.”
The new PSUs are already available. Pricing for Corsair’s new RMx Shift Series PSUs will start from US$150 (~RM636) for the RM750x, US$160 (~RM679) for the RM850x, US$210 (~RM891) for the RM1000x, and US$270 (~RM1146) for the RM1200x. At the time of writing, local pricing has yet to specified by the brand.
(Source: Corsair)
Filed Under Corsaircorsair rmx shiftpsusrmx shift
Updated 4:30 pm, Thu, 2 February 23
http://lowy.at/oN7XC
Share1Tweet1SendShare
    Transportation
    Transportation
  • Wanista
