iOS 16.2 carries quite a number of new features and security updates but as Malaysian iPhone users, we also receive extra telco-related features. With the new update, Maxis customers can now also migrate their physical SIM card into an eSIM directly through their iPhone via a feature called eSIM Quick Transfer.
With the new feature, they can also directly transfer their existing eSIM from the old device to a new iPhone or iPad by themselves. Prior to this, customers have to visit a Maxis store in order to perform such transfers.
To move away from your existing physical SIM card inside your iPhone to eSIM, head on to Settings > Mobile Data > Convert to eSIM. Just follow the on-screen instruction and you will eventually end up at Maxis eSIM Transfer mobile webpage that will require you to input the owner ID number as well as your e-mail address.
From what we know at the moment, Maxis is the only Malaysian telco that supports the new eSIM Quick Transfer feature so far. For further details, do check out the eSIM section of the Maxis website right here.
[Thanks for the tips, @tcp_asdf / Twitter and Teh Kh / Facebook.]
