As announced during the tail end of November, the realme 10 Pro+ 5G has now been officially launched. Just as expected, it is not making its debut on its lonesome, as it is accompanied by the other member of the family, the realme 10 Pro. Going over their specs, we see slight variations between the local models compared to the ones that launched in its home market.
Starting with the realme 10 Pro+ 5G, we’re looking at a mostly familiar device, with the 6.7-inch Full HD+ display with its 120Hz refresh rate. Inside, it runs a MediaTek Dimensity 920 chipset, instead of the Dimensity 1080 that we saw previously. The battery is at least a familiar one, rated at 5000mAh with 67W charging support. It sports a 108MP main + 8MP wide-angle +2MP depth sensor camera combo at the back, with a 16MP secondary shooter in a punch-hole cutout in front.
Moving on to the realme 10 Pro, we see the familiar 6.72-inch Full HD+ display with 120Hz refresh rate on the outside. On the inside, there’s the Qualcomm Snapdragon 695 chipset, 5000mAh battery with 33W charging, and 256GB of storage. But where we previously saw up to 12GB of RAM, the device only comes with 8GB of RAM locally, with an additional 8GB in Dynamic RAM Expansion for what it’s worth. Cameras return to familiar territory, with a 108MP main + 2MP depth sensor combo at the back, with the 16MP shooter in front in a punch-hole cutout.
For their prices, The realme 10 Pro+ is priced at RM1599 and RM1799 for its 8GB + 128GB variant and 12GB + 256GB variant, respectively. Worth noting at this point is that both also support Dynamic RAM Expansion, using the same amount of space as the available RAM for each respective model. As for the model without the Plus, the single variant will come with a price of RM1299. They are available for pre-order until 16 December when they can be purchased.
