There are only a handful of graphics card manufacturers that have released their take on the Intel Arc desktop GPU with one of them being the Taiwanese hardware company, ASRock. Almost two months after the Arc A380 Challenger ITX was released on our shores, its two higher-end siblings have finally made their way to Malaysia.
Specifically, the two models come in the form of Arc A750 Challenger D OC and Arc A770 Phantom Gaming D OC. As noted in our previous report, the Arc 7xx Series have been designed mainly for high-performance gaming.
Being higher-end models, this also means that they consume more power than the A380 as noted in the general specification list above. According to ASRock’s website, both of them are equipped with two 8-pin power connectors as well as 8GB GDDR6 VRAM.
Of course, another major difference between them is pricing. In an announcement by Achieva Malaysia which is the distributor for all three ASRock Intel Arc cards in Malaysia, the Arc A750 Challenger D OC costs RM1,499 while the Arc A770 Phantom Gaming D can be obtained for RM1,770.
