Hisense Malaysia has launched a new lineup of 4K smart TVs called the A6100H. It comes in a range between 43-inches all the way to 65-inches, and is currently available on Harvey Norman as well as some authorised Hisense dealers on Shopee.
The TV comes with a 3840×2160 Ultra HD panel with what the company calls a “bezel-less design”. The A6100H series unfortunately lacks local dimming but it is certified with HDR 10 with optimised profiles for scenarios such as gaming and watching sports. It also has an automatic low-latency mode that minimises input lag when it detects a gaming device being plugged in.
The Hisense A6100H series runs on the VIDAA U5 operating system that comes with a web browser, Netflix, and YouTube. The included remote control also enables voice control, which allows you to use voice commands to control the volume, channel, and perform other voice assistant functions. There is also a remote control app available that allows you to manage the TV via your smartphone.
Image: HisenseAs for ports, the TV has three HDMI 2.0 ports, two USB 2.0 ports, an AV input, a radio frequency input, an optical digital audio output, an ethernet port, and an earphone jack. It also supports Bluetooth 5.0 and dual-band Wi-Fi. Besides that, the 4K TV series from Hisense sports two built-in speakers that support Dolby Digital and DTS Virtual X. The power output depends on the model that you get, with the top-tier 65-incher featuring 10W speakers while the rest of the lineup are equipped with only 8W speakers.
The Hisense A6100H series starts from RM1,499 for the 43-inch model while the bigger sizes are priced at RM1,899 (50″), RM2,099 (55″), RM2,299 (58″), and RM2,999 (65″). Some of the aforementioned authorised dealers are even selling the new TVs for RM100 less than Harvey Norman, although it’s uncertain how long this promotional pricing will last.
(Source: Hisense)
