Just days after the company starts shipping the M2-based MacBook Pro 13 to Malaysian customers, Apple has since revealed that the equally new MacBook Air M2 will be heading to our shores in July.
This is according to the notice on Apple Malaysia’s website although the exact shipping date remains unavailable. When it comes to the price tag, it remains unchanged as per our previous report.
Regardless of memory and SSD choice, MacBook Air M2 with 8-core GPU comes standard with a 30W USB-C power adapter. If you prefer the higher-wattage 67W power brick or the new 35W Dual USB-C Port Power Adapter, you then have to fork out an additional RM80.
This also applies to the base configuration of the MacBook Air M2 with 10-core GPU which has 8GB memory, and 256GB for RM5,899. However, once you bump up the storage to 512GB which would then increase the price tag to RM6,699, then only you get to choose either the 67W solo USB-C or 35W dual USB-C power brick without additional cost.
Do note that the MacBook Air M2’s fast charging feature requires the 67W USB-C power brick although it is hard to deny the convenience that the 35W dual-port charger is able to provide. Meanwhile, the fully maxed out 10-core GPU option for the laptop carries 24GB memory and 2TB storage alongside a price tag of RM10,699.
