Illegear has recently unveiled an external liquid cooling system that is designed to increase the CPU and GPU cooling capability for selected gaming laptops. Aptly called Flow, the company claimed that this cooling solution requires a very minimal setup given its plug-and-play nature.
This is made possible by the self-sealing quick-release connector that has been equipped to the tubes on the Flow. Inside its enclosure, the Flow also carries a 120mm x 25mm fan and a 120 x 27mm aluminium G1/4 12-pipes radiator alongside a pump that has a head pressure rating of 2.3 meters as well as a flow rate of 220 litres per hour.
Once connected, users can check out the Flow’s fan and pump status inside Illegear Command Center software. From there, they can also tweak the fan’s performance profile as well as the system’s RGB LEDs.
Illegear said the fan speed can be reduced to as low as 50% when a compatible laptop is plugged into the Flow. Subsequently, a slower fan speed also means a lower noise level as well.
